Got my Heli in
jstang6969
Its an eflite blade. I can see this is gonna be frustrating. Seeing as I dont even know how to power the thing up:\
Can anyone chime in on how to recharge the battery using the charger with the aligator clips by chance?:first_place:
http://www.horizonhobby.com/Products/Default.aspx?ProdID=EFLH1105
thats the model.
As for the charger, A guy at the lhs said that the clips would be used for an A/C charge, not a D/C....that I dont have the plug for the wall either.
Thanks Rolex. Sorry about that bad link. That one should work now.
Don't mean to sound like a d!ck, but did it come with a manual?
In short, the battery should have two plugs. One will fit in the side of the charger, it's a balance plug. The other (probably red) is the power plug you power the heli with. Clip the charger to a 12v battery, plug the white plug into the charger, check the LED indicator on the charger till it says it's done.
BTW, the E-Flight chargers suck balls. I use a GP Triton and the GP 4 port chargers. Much better chargers IMO.
