Going Electric Help Help Help Pt2
Tarant
Medford
Ok in a few weeks I will be ordering my RC10T4 SE and i was wondering what are some good allround tires I was thinking Moabs 2.2. I will be bashing in grass, road and gravel and what should i use for front tires would I get better steering and traction if I put Moabs upfront as well. or sould I use rib type tires. and I will be getting some of this battery packs that are 3000mAh and what would be a good charger for around $50 I was thinking Duratrax Piranha AC/DC Digital Peak Charger.
Thanks
bustedgears said:
I'd stay away from duracrap
Buy a dynamite charger, they're much better.
Please put some substance into your posts. If you are going to say something is bad, let us know what it bad about it. If your going to recommend something tell us why.
Your post was useless!
I haven't researched the Pirahna, but the ICE from Duratrax is prety good, although it does require a seperate power source.
In the alternative, I use the MRC 959. Works well, has peak detecting circuitry, and is compact.
If I'm not mistaken Doesn't Traxx-ass own Dura-trax?
and also own Dynamite?
I was told this by my LHS.....they are usually correct on that sorrt of info....if so then your post was pointless.......if it's not true thenI'm an ass........
