The watery thin stuff sets quick and holds hard, but man, does it set quick. It's nearly instant. I use AKA glue usually, but I bought some starbond stuff off amazon that I have yet to use. I keep my CA in the refrigerator. Seems to make it last longer since I don't use it that often.
For preparing, I use DA on paper towels to clean the bead of the tires really well and the rims where the bead seats. Tires usually come with some release agent on them from the molds, so cleaning the contact areas is a good idea. Then I use a large sand drum on my dremel to lightly rough up the tire where it touches the wheel to give it a little bit of tooth. I use fine sand paper on the bead of the wheel with my hands to take the shine off it. This seems to help with longevity.
Then I mount all 4 tires on the wheels, get them lined up nice, roll the wheels in my hands while compressing the foam/tire some to just kind of work them a little, then I line the beads all back up to flush again and start gluing. Since I use the watery stuff, it sets nearly instant, so I pull the bead back a hair and put a tiny drop, then press the bead against the wheel, wait a few seconds, then move a little bit, pull the bead back, drop, press, wait, etc.
DO NOT STACK TIRES TO DRY!
DO NOT PLACE THEM ON A CLOTH TOWEL TO DRY!
DO NOT PLACE THME ON ANYTHING YOU CARE ABOUT TO DRY!
If you can find something to put them to dry on so the tire touches, but the wheels don't, that's likely best.
