gillbot said:
I was just concerned because of all the "cloud of mystery" surrounding nitro cars and people stating the maintenance was too much.
I guess it also depends on what to much is. Pretty much the only extra components you have on nitro is one more servo (throttle/brake servo instead of ESC), mechanical brakes, engine and flywheel clutch.
Electric motors have to be maintained as well. From what I've read, to keep top performance on a motor, you have to cut the comm's, deal with the brushes and springs every 20-30 runs or so.
For a nitro rig, you can get about 7+ gallons out of an engine before it needs a new piston/sleeve or pinch.
With a 75cc tank (NTC3), that's about 50 tanks (or 50 runs) at roughly 8-10 minutes per tank for 1 gallon of fuel.
Depending on the clutch you run on the engine, you may have to take it apart and re-rough the shoes about once a gallon. I run MT's and that's about how often I do it. About every 3 gallons, I replace the clutch bell bearings. I've been running the same shoes on my savage for 8+ gallons or so.
Other than the nitro mess that comes out of the exhaust, glow plugs and clutch maintenence, there is still all the other stuff you have to maintain on both electric or Nitro. CVD's, bearings, bushings, ball cups...
The other bonus of nitro is that you don't have to wait for your Engine to cool off before running it again. At least after you do the break in process. You can run it all day long or until you run out of replacement parts from smashing into stuff.
