Originally posted by Çh®i§tiªñ
Heat hurts batteries, yes.
Over dischargin them can be the worst if not done properly. Most overlook that. You should NEVER discharge below .9v per cell. NEVER! If you use a light bulb dimmer and have no way of knowing, then I suggest pulling them off as soon as the bulbs start to dim. Equalizing trays/dischargers with voltage cutoffs are probably best to have. Fortunately, my charger has a preprogrammed cutoff when discharging of .9 v per cell. This alone is a HUGE bennefit.
After your runs it is best to let both the motor and the batteries cool down before discharging your battery pack.
Heat = Bad !
The answer is yes.
