Gas isn't so expensive that I worry about losing a little gas. I make sure the tank is empty and the engine has burned off all the remaining gas in the fuel lines and carb before I am done for the day. Then, I set the flywheel to BDC before it cools down.
If I'm not going to use the car for more then a few days, I also put in some after-run to help fend off corrosion.
Taking a little care of the engine can really extend it's life.
