Fsr-026 blade gas powered rc boat 26cc
Big Ben 521
I would like to know what the fuel mixture is for my fsr-026 blade gas powered rc boat 26cc and what kind of oil and what kind of gas to use and if there is a break in period and it doesn't say anything in the manual thanks
Thats the problem with those AliExpress specials. They never come with instructions. I can't say for certain as I've never owned a gas powered RC but I'm assuming its a typical 2 stroke engine which will use 2 stroke gas but I'm not sure if the gas to oil ratio is the same as for say a weedwacker. Like a weedwacker I would also assume theres no break in needed but I'm sure someone more familar with gas RCs will chime in with more detailed info.
Off the top of my head, I honestly don't remember what the fuel mixture I use is but I do use a bottle like this. Pretty straight forward and simple. Just match the levels.
8 ounces to a gallon of fuel. I don't use pump gas and you shouldn't as a lot of it contains ethanol. Buy Recreational gas. I use Coleman campstove fuel myself. Use a synthetic 2-stroke oil. I use Lucas but there are many other great brands out thee.
You shouldn't need a break-in but if you want, run it a little rich for a tank of gas.
Thanks everyone. We'll I put fuel in for the first time now and I pulled on the cord and pulled and pulled but it will not start. Can I get some help with this issue
You have get the as o the carb. From here choke the carb until you get some gas on your finger pulling it slowly then give it a few pulls until it fires up. Make sure that the barrel is opened slightly.
I have the same boat and what a piece of junk. I’ve had so many things wrong with this thing I don’t know is leaking through the exhaust system water Bellows out my pull starter broke etc. do you know a good place to get parts besides Ali website
Big Ben I have the same boat I just got Done breaking it in this is what I want by
