Jaydiaz1993
RCTalk Champion
So today I've decided to finally change the spur gear on my Rustler/Jato built recently I had a 54 teeth spur gear but with that set up I could only reach no more than 56mph no matter how I tuned it, rich or lean. I've had the 50teeth spur gear from the Slash for a while now but I knew it would be a pain in the butt to change the gear since I would have to trim off the spur gear cover and play around a little bit to get it to fit.
Once I trimmed off the spur gear cover I proceeded to remount the engine and while remounting it I added extra washer on top of the washers the engine mount already provides in order to raise the engine high enough that the clutch bell would reach the new 50 teeth spur gear with ease.
Once the engine is in place it should look something like this
That's pretty much it... if I have the time later on I will take it out for a speed run and see how much it improves in overall performance and mph
I'm curious to see...
Will it perform better than the 1 speed Rustler, worst or about the same?
