On my Kanai 2 / RB WS7-2 combo my flywheel is loosening.
Problem is this: If i tighten the flywheel nut to tight, the flywheel is pressed against the engine case and therefore the flywheel won't even turn over. But if I just hand tighten the flywheel nut not using a plier, then the flywheel loosens up.
Anybody else is having those problems and has found a solution?
Thomas
Thomas
