This past weekend I took my Hobao(Hyper) Mach .28 engine apart mainly to seal any air leaks I may have. I had a tuning issue last time I ran it, as it only ran well with mixture settings that gave me 290 deg temps, so I shut it down and decided I probably have air leak(s).
This was my first look inside one of these engines, and I marveled at every part I took off.
I've run about 3 quarts of fuel through it, and I was amazed at how clean it still was on the piston crown, and in the case. I use aro religiously and set to BDC, but I didn't expect it to still look new in there, especially after the breakin time running so rich,,I guess my 4 stroke gasoline engine experience is trying to tell me it should look much different,,lol.
Anyway, it is a P/Start engine, and after I pulled teh backplate off, there was a "turbo fan"(for lack of a better name for it) that incased the one-way bearing and had the pin that went inside the center of the crankpin(rod-journal).
Is that fan standard on these engines?
I was very surprised to see a high polished aluminum connecting rod.
Also, I pulled the head (heat sink I think most here call it,,with good reason as I didn't know there was a "head-plate" underneath the heat sink.
Is there a specific torque value for the heat-sink/head screws? They were tight as hell breaking loose, so I torqued them as tight as I felt comfortable with going back together, a lil on each at a time in a pattern so as to make it even.
Also, I did the "quench" check for the piston-head clearance using a small piece of solder,,it came out .045" both times that I checked.
I thought it should be closer to .020" for these engines?
Anyway, sorry it's such a long post. I'm an engine "nut"!
Jeep
P.S.
The exhaust port in the sleeve matched 100% with the case exhaust port as if it was "port matched" ,,is that normal for these engines?
I expected a bit of a "lip" on one or the other or both.
Jeep
P.S.
