KnightAzul
I have an Thunder Tiger TS-4n Sport 4WD (RTR) and noticed that the steering was not tracking well. After some discussion on a previous thread (thanks SkyMaxx!) I ended up buying as a first hop up:
- HiTec Aggressor CRX digital 3 channel transmitter + receiver combo, which came complete with one HiTec HS-325HB servo.
- Ko Propo FSA-1 Failsafe.
Due to this being my first hop-up and also not having all of the right tools (typical of a newbie!) I managed to take shear off a small (0.5 cm) section of the sleeve off of the antenna near to the receiver. The wire was exposed slightly but not cut. Nothing a bit of electrical tape can't hide!
After having finished with everything prefectly tie-wrapped, a flick of the receiver switch (transmitter off) and my pride and joy is break-dancing! Both servos, steering and throttle/brake, are going mad and tending towards one direction (brake on, steering full-lock right). If I wiggle the antenna wire then this seems to affect the servos even more.
All of the evidence points a thick sweaty finger at the antenna. I though it worth a post in case it could be something else with this being my first hop-up and all. Could there be an appliance in my house which is causing this? and the electrical tape really is doing a fine job?
Thanks,
KnightAzul
Thanks,
KnightAzul
