Element Enduro Sendero SE with Ecto parts
332_RC
Bashing/On Road/Crawling
Rig of the Month Winner
Build Thread Contributor RC Showcase: 14
Picked up a new Element Enduro Sendero SE slider cheap. Threw the leftover Ecto parts on it. The Reedy ESC & 14t 550 brushed motor & Ecto tires went on & I had a 6.0v 18kg servo I never put in my Boomerang & mounted it up. This chassis is a servo on axle & composite 4 link. Has a forward mounted motor, pretty cool, & a 1:1 gearbox. Should be a fun trail truck. Just need a body, receiver, & radio.
@majin You would have to remove the wheel wells and side guards that the esc, and receiver box are on. It's too wide. Otherwise yes the Ecto body will fit. The chasis is the same on all Enduro models.
very cool, will the ecto body fit?
Nah, unfortunately, not.
Correct. I already mocked it up.
I believe I'll get a Jconcepts 82 K10 square body shell. I use to have a 81 GMC I drove for years. The decal sheet has the exact same grill. 🤩
Oh, and if you do happen to grab that Pro-Line set, you're going to want this pdf, which is this template sheet. The attached pdf should print actual size to cut out the hood opening.
