ECX Curcuit Flip/Gearing Reccomendation
F.R.S. Ninja_007
Paris somewhere
  3. Scale Builder
So I got an ECX Curcuit and I’m flipping it. I already installed a brushless system and a new receiver, but want a receiver box. Also any suggestions on being able to use a 3S LiPo? The battery tray barely fits my 2S.
Update: I just took apart the truck; parts that will need replacing are the shocks (I’ll be upgrading to aluminum), gear cover, screws, and wheel nuts will need replacing. I found a spur gear for it but the screw that secures the pinion is stripped. That and the pinion I want to replace. Any gearing recommendations from ECX 2WD owners?
Use a dremel to cut a slot for a flat head screwdriver on the screw or you could just cut the head. I've got an amp and have never used the cover in my opinion theyre useless
That’s a good idea I’ll look into it. But I need the gear cover to protect it while bashing.
