Watchman
Hi folks
Just about to glue the lower deck on my first model rc boat.
Hull is abs deck is plywood.
Unfortunately due to inexperienced sanding I have a small gap around the hull part of the lower deck.
Can I use e6000 to glue the deck to the hull and then when e6000 is dry fill in any small gaps with slow cure epoxy?
Lower deck has the motor mounted on it so will vibrations cause the gaps to crack?
Thanks in advance for your help
