Dual Lipo
DirtRider045
RCTalk Racer
Minnesota
I got two 2s 7.4v venom lipos that i run in series in my tmaxx. Does this mean that i have to still run my lipo cutoff at 4s or can i set it to a 2s cutoff since its two different batterys?
4s or 12v other wise it wouldnt cut off until 6v if you did 2s and it would be the end of the packs.
What esc are you using? Can you set it to a custom cutoff? If so, I like to add alittle, like 3.1 or 3.2 per cell, which would be 12.4, that gives you a little more assurance...
I'm runnin the castle mamba monster system, i think all i can set is 5,6,9 and 12 volt. Unless maybe if I plugged it into the computer.
You havent plugged it into the computer? Do that and you will be able to adjust alot of stuff.
