2WD correct?
Did you upgrade to a sealed diff? I believe the stock diff is not sealed.
If you have a sealed diff then anywhere between 2K to 5K is your "tuning window" with the following behavior within that range, only look at the rear option in the chart below where I would start with 3K.
If 4WD then I would start with 7K Front, 7K Center and 3K rear with the following ranges:
Front between 5K - 20K
Center between 5K -100K
Rear between 2K to 5K
*** If you go outside this recommended tuning window then chances are you need to make other changes to your setup instead where tires are the very first thing to tune before anything else
FWIW, you'll never get a 1/10 platform to handle like a 1/6, just not gonna happen with completely different geometry, weight, etc
That's like asking for a Ford to handle like a Ferrari... take the bait?
