Greywolf74
I'M TO BLAME!
Lifetime Supporter!
RC Showcase: 8
I have a gearing question about the DESC410R. I'm going to be using a MMP with a 5.5T SC4X Sensored Tekin Motor. I will be bashing and a little bit of rookie class racing as I'm fairly new to the hobby. I have two questions:
1) Should I run the stock spur gear and if so what is a good range of pinions to use with this set up?
2) If I should should change from the stock spur then how many teeth should I be looking for and again what pinion range should I look at using?
Thanks in advance.
Thanks in advance.
