- Bomb Pop Island
- Racing
Welp, I haven't truly taken this fully apart since I built it in late 2022 so I think its time for a rebuild lol. Here is some before pics. Gonna start this weekend. Should have started it last weekend where I couldn't have went to the track but it is what it is. First need to get this terribly stripped up screw. Yes @Littlemotor I tried punching in some torx bits. Bought a Amazon T1-T10 bit set a few months ago which are too small. Had a T15, T20 and 25 in the tool box. 15 was too small. 20 was too big. Gonna take it to my uncle with the power tools this weekend. Could still probably go to the track this weekend and not bring this car but id rather stay home and rebuild. Plus I only have 10 bucks which won't get me into racing so. Lol. Gonna pull off the front and rear clips. Clean up everything. Freshen oils in the diffs and shocks. probably won't pull up everything on the chassis since I need a new roll of 3m sided tape and also simple green. Or you know what Ill stop by autozone or the harbor freight tmrw. Do need to replace the front diff case as I been needing to do that since September lol bc the sway bar mount where the screws go in are too stripped out so. Should have also picked up a new Fast Eddy Bearing kit but ill save that until sometime else. All the bearings, besides the center diff ones are good. It's been running and driving well but just needs a clean up. Deep clean in the hard to reach spots basically. Oh yea, maybe replace diff outdrives and pins in the CVAs? Or should I just leave it as is? Also, any tips on how to get the rear ride height lower than 20mm? Shock collar is all the way up and the shocks been bled many times and no air in them. Maybe something with the shims with the arms/pins?
