tudordewolf
Got the itch for biplanes recently and this kit caught my eye for cheap. Having built one of their foam/ply planes before, I figured it'd be a nice "break" and a fun first biplane. It has been one of the most technically challenging builds I've ever done.
It uses a classic wood frame for the fuselage. I always love piecing these together and seeing a sturdy 3D shape come to life from the delicate wood features. The manual suggests piecing it together then just zapping all the joints with super glue, but I like to go slow and use wood glue & clamp any wood-to-wood connections, it's just... so much better.
You then 'skin' it with pre-printed ~3mm foamboard, which is tricky to position and glue without breaking any of the features underneath. To get it to line up with the holes it needs to match on either side of the fuselage, I had to gently "stretch" it over the curved portion. I accomplished this by marking the foam & gluing the center first, then doing the sides:
You can see in this pic the degree of stretch, kind of a cool, "canvas" effect, just so tricky to work with...
It uses a similarly interesting hybrid structure for the wing. Wood ribs form the airfoil shape, carbon fiber rods provide stiffness, and that same printed foam-board as on the fuselage forms the skin and remaining structure of the wing. Much like the body, getting it glued and lined up is pretty difficult, while keeping the wing straight. Ironically the first few sections I did came out pretty well, I can even see straight through the holes in the ribs of the top wing all the way through to the other side, and then the very last one, a lower section, came out so twisted I've ordered a second kit just to finish the first one properly. Given the time invested, It's worth it at this point.
To make the leading edge curve fit the ribs, I had to cut out a relief groove from the back of the foam (not in the instructions, my own addition), without slicing all the way through: (I did in a few places, a bit of tape on the outside patches it up fine)
Tiny wing servo mount, a 4.3g servo:
I added some reinforcement, not even full stringers but just strips cut from the scrap ply, to the portion of the fuselage where the tail begins, it felt like too little structure at a crucial section of the plane. After of that part it gets "denser" and everything is closer together so its less flimsy, though I did snap that one tombstone-shaped piece at the right of the image 3 separate time, before assembly, during assembly, and once after while wiring the servos.
The tail is another marathon of challenges: you need to cut the bevel for the control surfaces into the 5mm foamboard yourself:
And use a torque rod to actuate the split tail using only one servo link:
Making the elevators work with that was its own challenge, it won't just slide into the foam, it tears it if you try. I wound up having to drill them with a 1.5mm bit, I used my tiny drill press to keep it straight, but I don't see how they expect people to pull that off on their first try. I thought I snapped a pic but can't find it.
You also need to cut slots for hinges into the foam yourself, a task made substantially easier by the vicious looking slot hinger:
And prepare the tail for the rudder by cutting away excess foam:
But once it all comes together, it is pretty rewarding seeing the bevels you cut allowing the swivel of the rudder.
The stock power setup recommends a 2212 motor, 20A ESC, and a 1300mAh battery, all of which I found a bit heavy-sounding for a plane this size. I spent entirely too long on https://rcplanes.online/calc_motor.htm trying to find a more optimized solution, until inspiration struck - this little 800kv, 30g motor will produce 450g of thrust on only 6A of current, spinning an APC 9x3.7SF prop, as verified by my highly sophisticated test equipment:
That, with a little 'XP-12A" ESC, cuts 70g of weight, 18g from the motor and 10g from the ESC, (an ounce on the powerplant alone), and another 40g cut from the battery with an 850mah 3S. I haven't flown it yet, but I'm excited to see how it performs.
From this angle you can almost pretend it's not missing a wing...
