D3MON
Hey guys, been awhile since i posted, and been working with RC's in general, but started a project recently and wanted to share the build
Originally didn't think i was going to be doing a build thread on this, as it isn't for me and pretty personal of a project, though it is one i have wanted to do since i have been into RCs, albeit for different reasons and on a smaller scale than I initially thought.
Warning, this project was my first time utilizing Fusion 360, and my first experience with 3d printer and 3d printed parts, so if i am doing something completely wrong with either or both, which there is a very good chance of, feel free to let me know.
Picture of the truck for reference.
the truck is no longer around due to a forest fire, so i had to rely on a few pictures that i had over the years and scaled dimensions off a 5-gallon bucket that was in one of the pictures.
when i started this build initially, there were 2 different lengths to the SCX24, the SCX24 deadbolt (SWB), and the SCX24 Wrangler JLU.
this eventually changed and the SCX24 jeep Gladiator and Dodge Power Wagon were made available with almost a 2cm longer wheelbase, which i opted for in effort to make it more scale.
It started with ordering a 1/24 scaled 3d printed body from i think "Etsy"? i had even less of an idea at the time, but the body was 3d resin printed, which kind of has some issues, but i believe will be able to make it work, all else fails i have a .stl file of it and will be printed in ABS or Petg.
using Autodesk Fusion:
slow process of learning Autodesk Fusion, but the start of the headache rack and flatbed
attempting to learn and understand how "bodies" work and struggling with keeping some parts separate in case of changes to length and location of parts change (which they did).
this version i had tried making slightly longer as you can see by the spliced section, ran into some struggles with the parts underneath, but was able to manage.
once i got this far, i sent it to a friend to get the first test print. we opted to use Petg filament.
after printing found a few issues and around this time was when i discovered that the longer wheelbase Jeep Gladiator was available.
i had made a few of the dimensions too thin and we were getting separation of components.
once the first test print was done i finally decided i wanted the bed and the cab to be attached as one unit, and came across some threaded inserts to make that happen so revisions had to be made to incorporate them in a hidden location so more revisions were to be made.
revised body design in Fusion and a test fitting:
as you can see i thickened up in front of the under bed mounted toolboxes, giving room to install some threaded inserts. i thickened up the triangulated pieces in effort to prevent the pieces from not joining/bonding. i also extended the chassis 2cm aprox to get the dimensions somewhat correct to the SCX24 chassis, i think it is still too short vs the 1:1 but much longer and it would have not looked good on the truck.
2nd print of the bed and mounting to the body:
second print came out alot better, the pieces was revised to be thicker to not separate:
also seen in the above picture is the thicker toolbox back piece to allow the threaded insert seen below
once the holes were drilled and the inserts were heated and melted in, made a mount on the back to screw to the back of the upper cab:
this is where there were slight problems with the body itself being resin printed. (at least with me not knowing it was.)
the bottom left corner was narrower on the print than the right, coupled with it being quite brittle as it is resin printed, it snapped off as you can see. also you can see the back of the cab has a few cracks in it as the whole back broke off as i attempted to drill it.
for now i managed to glue it back together with some shoe goo and a few pieces of wire to add strength.
as you can see it does mount up, made sure to use washers to make it have a more spread out clamp force. time will tell if it will last or not.
picture of the bed mounted to the cab.
overall at the time was happy with how it was coming out.
at this point i was waiting for the truck to figure out how i wanted to mount the bed/cab combo to the chassis of the SCX24.
