converting a slash to a mid motor rusty.
luke66
Build Thread Contributor RC Showcase: 9
State of Country Music.
as the title says, i'm literally right in the middle of converting a slash to a mid motor rusty. i have parts strewn about my entire shop.
AND its like 90 degrees out. i have no A.C. this is the most strenuous build I've EVER done.
i have the front part of my slash on the rusty chassis. i have to saw off part of the tranny to get it to fit on.
this is nuts.
Edit: this isnt the build thread, just giving yall a heads up!
as the title says, i'm literally right in the middle of converting a slash to a mid motor rusty. i have parts strewn about my entire shop.View attachment 170527
this is nuts.
Why don't you Dremel the battery compartment, turn the tranny around and reboot.
As for heat, open the second window for a cross breeze and add a fan.😎
idk if its gonna help handling that much. well have to see. i think mid motor would make it a little less drifty, cause the weight is all infront of the tires. i mostly did my conversion for the lcg. and so far I've only spent 10$. really couldn't pass it up.
Way back in the long long ago, I did a similar build. How did you, if you did, compensate for the slope the tranny sits on which is then reversed when you flip the tranny around?
