Connectors type for 24v Li Ion battery
mikeziele
Hi,
Any one knows what kind of connector types are these?
I'm trying to connect my Traxxas lipo battery's to my daughter 24v electric balance bike,I want to use 2x 6s lipos to get 22.2v. so I can get more run out of it, but don't know what type of connectors are these.
Maybe someone will know here? Many thanks for any info
Mike
They remind me of anderson powerpole connectors... they aren't though. They appear to just be a hybrid spade connector. You could likely cut them off and put some xt90/xt120's on there instead.
looks like a blade connector-5/16" to me. If i was You Id just find out the total amp draw needed for E bike and make my own from a Anderson power pole. much easier to get ... a fully charged 6 cell is 25.2 volts. now the 2 -6 cells will be in parallel correct?
Thanks for the quick reply. Yes I think. I'll just do this, it's going to be easiest this way.
Many thanks
Yes the 2 lipo batteries i have are 11.1v Traxxas 5000mah. And I want connect them in series to double the voltage to 22.2v, and 5ah will stay the same.then connect them in parallel to the bikes battery. The bike has a li ion battery 24v 5Ah. I guess the easiest will be to just cut the old connectors, and do my own connection as you said.
Thanks for you quick reply.
Regards
Mike
ok not quite what I said. you have 2- 3 cell lipos...then yes it is in series..
seeing those wires in pic are all under 12 ga and that the minimum ga wire Ill use in any rc even my 1/18 scale9not really into micro rigs just too toyish) so a xt 90 could work..even a 50 amp power pole... but they are not a solid connector xt 90 are.!
