- Northern California
- Racing
- Crawling
So wanted to do some testing with some of my new packs from my sponsors at CNHL. Ran both the G+ 70c 6000mAh 6s and Racing Series 90c 9500mAh 6s packs. Setup is an Arrma Limitless with XLX2 and 1717 1650kv motor using perfect pass on 1:1 gearing. Results were really really close so this will be done again in the future to see if there will be a bigger variance between the two packs. So results were the G+ pack ran 124mph with minimum voltage dropping to 20.9v, .67v ripple, 284.4A and 8.2HP/6115W.
The R.S. 90c pack ran at 123mph(on a 200ft shorter pass) with minimum voltage dropping to 20.7v, ripple at .96v, 271.1A and 7.88HP/5876W.
So mph wise I'm saying packs were identical taking into consideration the 200ft shorter pass with the 90c as if both passes were same distance I'd bet they'd have both been 124mph. The more important data to me being the voltage and also amperage is where the variance is more important. The smaller 70c 6000mAh pack kept better voltage but produced higher amperage, where the bigger 90c dropped more voltage but had less amperage. So again this will be done down the road and with heavier gearing and load to really test the packs and get more variance hopefully. In short with the close results about all I'm concluding is the larger 90c pack should do better on a heavier load/higher gearing as it had less Amp draw where the smaller 70c will do better on less load but not by much. Just too close of results only thing to really consider is the size of the packs and how the smaller pack did the same or little better than a pack 1.5x the mAh which is interesting.. Here is a short of the passes and I'm working on editing up the full video as well
https://www.instagram.com/reel/CUgshQKlY1y/?utm_medium=copy_link
