clutches
MaxiMumST.2002
RCTalk Racer
When you buy a new engine does the clutch usually come equipped on the engine or do you have to buy1? I recently purchased a wasp .18 engine and i was wondering if the clutch comes on it? I ordered it from towerhobbies.
Thanks
If it comes with a flywheel, and bell housing then most likely it should come with a clutch. What is it going in. I'm looking at a Epic .18 or a Wasp .18 send me a PM and tell me what your thought are about it.
when putting a new engine, u have to use the old flywheel and clutch set up on ur new engine. new engines dont come with the clutch set up.
later
Originally posted by Maxx Trooper
when putting a new engine, u have to use the old flywheel and clutch set up on ur new engine. new engines dont come with the clutch set up. I could understand useing old clutch and clutch bell but what the old flywheel. For instance would a .15fe flywheel fit a .18 wasp or a .18 epic? Explain, I've yet to do a engine swap.
later
yes that flywheel will fit that shaft, becuase i believe it uses a collar that goes on the shaft, followed by the flywheel,t hen u tighten down the clutch nut on the flywheel. most engines are made so u can use the old flywheel and clutch setup, but there are different shafts and different shaft lengths. like the t-maxx is a short shaft and a HPI is a standard shaft. can't think of a company that uses the long shaft. TRAXXAS use to use the long shaft in the Nitro Hawk.
later
later
Damn, I guess ya learn somethign new everyday. Thanx
