clutch engages at idel
welchdennis63
RCTalk Racer
phoenix, arizona
i have a axial .28 running a stock t maxx flywheel and clutch and I'm killing the clutch after just a tank or two so i need a stronger clutch does anybody use the integy 3 shoe clutch setup and i was told to get the integy and i could run a set of BB clutch springs I'm not sure what do you guy think thanks for reading
Integy uses fairly low grade aluminum and almost all their products are know to be crap, aside from their tie-rod eliminator hubs. I'd sugguest getting Dynamite Max-Life or Nova RC's clutch shoes with harder springs to hold the shoes for later engagment.
Integy is known in addition to their use of inferior grade of materials, for a lack of customer service.
with the stock flywheel or with the 3 shoe flywheel?
I prefer the 3 pin flywheels, I've had better experience with three shoes.
what shoes can i use with the 3 shoes flywhaeel for integy thats the only thing i wanted from integy and whats wrong with integy i have never broken bent or stripped anything from integy
The use really low grade 6061 aluminum which is weak and not very heat reistant which would be bad for a clutch.
