Clutch bell bearings
leaNMachine
RCTalk Racer
  1. Racing
ok so the prob is that every once in a while my e clip on my clutch nut expands and i lose one of my fifteen dallors bearing,I tried patriot rc beraring with about 1 tank and they fall to peaces,I need a heavy duty 3/16x5/16 flanged bearing that is goin to make me not want to sell my truck anymore beacuse there so exspensive!!
Instead of going the e clip (and losing it) route, the shaft is threaded (3mm id) just like most every other engine. You can always junk the e clip and hold the bearing in place with a 3mm screw and a shim or two as required.
+1 That is the only way i do it... just make sure to use blue lock tight.
EDIT - here is the Avid link
http://www.avidrc.com/product/1/bearings/11/316-x-516-Flanged-Metal-FR156ZZ-bearings.html
and thank for the avid link, i'll be using it from now on.
my clutch nut is not the male one its the female,i have an os 18 on it
thanx moto those bearing are great,just hope they hold up to the os power!!
I've been using the same clutch bell bearings for 2 gallons now. I just changed them out, mostly because I couldn't believe they lasted 2 gallons ;-) A lot of guys at the track just buy a sleeve at a time and replace em every weekend. At $1 each...it's hard to beat. I replaced all the bearings in my Truggy (every single one of them) for like $27.
yeah i bought 20 which is like nothing since one set is 15 plus tax,and for ppl who dont know 2 gallons is a long way for the bearings from high abuse of the engine,but anyway thanx alot for the link,saved my life!!!
