Here is my method....
1. Strip off engine and electronics
2. Remove Tires
3. Douse completely with 50/50 solution of Simple Green and water
4. Let sit for 5-10 minutes
5. Blow off with air compressor
6. Repeat steps 3-5 as needed until most of the dirt and grime is gone
7. Get the rest with a rag/brush
8. Let dry while I clean my tires
You can also use a garden hose instead of air compressor for Step 5 BUT if you do you will need to spray WD-40 all over the car once it;s clean to prevent any rust or corrosion. I typically cover everything in a nice thick spray (avoiding brake discs of course) and let it soak for 5 minutes or so and then blow off the excess with my air compressor. You can also wipe off the excess as well if you do not have a compressor.
Once everything is clean and dry I'll spray a tiny shot of lithium grease into my CVDs and then clean up the engine/radio tray/Body manually before re-assembly.
Everyone has their own methods...this works for me ;-)
