charger setting?
.15 amps at 1 C What is the C rating on the battery? Example: If the battery was or is 2C you could safely charge it at .3 amps, 3C .45 amps... (:
Pete
Most chargers don't have half step settings, so you're probably stuck with either .10 or .20a/hr. If the charger has a capacity cutoff, you can set that to 150mah, and charge at .20a/hr to ensure a full charge. If not, you can try .20a/hr just keep an eye on the pack and check it's not getting over charged.
