CorradoPsi said:theoretically when you go up in nitro you need to lean out to maintain the same A/F ratio. this is because the nitro actually is carring O2 in with it, in a denser amount than the ambient air. so to maintain A/F you need to reduce that amount of O2 comming in by leaning out the engine.
however if the oil package causes hotter running, i could see a need to richen up.
Leaning out the mixture will not reduce the oxygen content, it will increase it. To reduce the oxygen content (or increase the fuel content) you would need to choke the carburettor (not possible on most glow engines) or richen the needles.
Your experiences in retuning when switching to a higher nitro content kinda flies in the face of theory, but then the theory assumes that the methanol and oil content stays pretty much the same. Common sense dictates that if the nitro content increases by 10% then the methanol and/or oil content has got to reduce by 10% and changes in either will necessitate changes in carb needle settings (usually richer). It could also be that the 30% fuel that you used had a higher oil content than the 20% fuel and you could get away with running leaner.
I think the bottom line here is that if you switch to a higher nitro content, then some significant needle twiddling will be required. If the engine is producing more power on the new fuel then it is likely to produce more heat so pay particular attention to the head temperature and smoke trail and retune accordingly.
