I was recently given a Losi Nitro RC Truck, its one of the bigger trucks with big wheels. I know it's older but I can't find any markings numbers, or anything to identify which model it would be. Any tips on how to figure that out are appreciated!
I'll get some when I get home. I wasn't sure if there was a certain spot to look that I was missing.I do believe a few pictures would be helpful.
Here are some pictures, let me know of theres anything specific you want a picture ofI do believe a few pictures would be helpful.
here you go sir, sorry it took me so longI do believe a few pictures would be helpful.
That is an LST2. It has the original Losi Mach 427 engine in it, (after market pipe tho) and it has a couple of nice upgraded aluminum parts. The stock plastic shock towers are pretty durable, but if you're putting this thing 10+ft in the air, then aluminum is better. The aluminum steering knuckles are clutch. That's probably the most commonly broken stock part of these kits for me. Now that I think about it, I also broke a lot of a-arms and front shock shafts. The TiNi shock shafts you can still find on eBay, and they are a lot more durable.here you go sir, sorry it took me so long
Optimal traction in forward or reverse.That is an LST2. It has the original Losi Mach 427 engine in it, (after market pipe tho) and it has a couple of nice upgraded aluminum parts. The stock plastic shock towers are pretty durable, but if you're putting this thing 10+ft in the air, then aluminum is better. The aluminum steering knuckles are clutch. That's probably the most commonly broken stock part of these kits for me. Now that I think about it, I also broke a lot of a-arms and front shock shafts. The TiNi shock shafts you can still find on eBay, and they are a lot more durable.
If you can find RPM a-arms for it, Id get those too. If you're bashing really hard, you'll want to find some titanium steering linkages too. The metal guard/handle looking piece is also after market.
Also, I can't quite make out what wheels are on it, but they are not the stock ones which used 20mm hexes. Since it has after market wheels on it, then it's likely been converted from 20mm hexes to 17mm hexes.
If your transmission has a hi/low shifter knob on it, (can't see the tranny in the pic) then it's the original transmission. If not, then it's probably a transmission from the XXL. Same transmission, Losi just removed the low speed gear inside the original transmission case and then put a rubber plug in the hole.
Just a side note. Your passenger side rear tire, and the driver side front tire, are on backwards.![]()
Thank you for the knowledge! I haven't even been able to start it. All the battery packs are shot and I can't seem to find suitable replacements that have the right connectors on them. I got it from a fella amd it's just sat since unfortunatelyThat is an LST2. It has the original Losi Mach 427 engine in it, (after market pipe tho) and it has a couple of nice upgraded aluminum parts. The stock plastic shock towers are pretty durable, but if you're putting this thing 10+ft in the air, then aluminum is better. The aluminum steering knuckles are clutch. That's probably the most commonly broken stock part of these kits for me. Now that I think about it, I also broke a lot of a-arms and front shock shafts. The TiNi shock shafts you can still find on eBay, and they are a lot more durable.
You're welcome. The LST line is my all-time favorite rigs I've owned.Thank you for the knowledge! I haven't even been able to start it. All the battery packs are shot and I can't seem to find suitable replacements that have the right connectors on them. I got it from a fella amd it's just sat since unfortunately
