jalikaria24
The ports of the engine are in the piston/sleeve right? If so, I have a dynamite big red .28 and I also have a parts Losi 454. It seems like the Losi 454 has 8 ports while the big red has 5+1. So I bet that the Losi makes more power then the big red correct? Or is there something else that matters
My Losi is missing a crankshaft so if I put the big red crankshaft in the Losi, I assume i would be making the same amount of power as a stock Losi 454? I believe they are compatible cranks since theh both are sh .28. Or I could also put the piston/sleeve from the losi 454 into the big red but i feel like changing the crank would be easier.
Thanks!
Thanks!
