Build Thread Built TRX-4 Defender
floe
RCTalk Champion
Denmark
  3. Crawling
  4. Boating
Hi all
So this is the current state of my TRX-4. Think I have struck a good balance in terms of performance and weight distribution now. Upgrades as follows:
Chassis upgrades
  • Brass outer portal housings front and rear
  • Brass diff covers front and rear
  • Brass inner portal housings front
  • Brass C-hubs front
  • Brass lower shock mounts front and rear
  • Yeah Racing axles
  • Yeah Racing drive shafts
  • Aluminium wheels with brass inserts
  • Aluminium wheel nut covers
  • INJORA King Trekker tires
  • Aluminium upper shock mounts
  • Aluminium bumper mounts
  • Metal front and rear bumper
  • Metal pedal rock sliders
  • Full steel armor
  • Winch
  • Dialed in shocks with 10 WT shock oil
Electronics
  • Hobby Wing XeRun AXE R2 2100 kv brushless system
  • INJORA servo
  • Traxxas Pro Scale Lighting
  • ESS-ONE+ sound system
Scale Body
  • Laser cutted custom decals
  • Metal headlight grills
  • Metal window grills
  • Scale details air intake, hinches etc.
  • Painted scale accessories
Do you see a noticable difference in performance?
It's a different world. RPM matching with the AXE ensures that it keeps going at the same speed with the same throttle input no mater the incline. Furthermore the precision of which you can control the speed is much much better than stock brushed, and I can go way slower now, while keeping the same or better top speed.
The system is actually a bit too powerful to my liking, but that's an easy fix by turning the max power down.
It has Bluetooth and everything can be controlled through the hobbywing app.
It's a win. Rather expensive though.
Just installed a couple of Yeah Racing axles and drive shafts. Haven't measured the original parts but should add +200 grams of unsprung weight.
The truck is almost done now. Need a couple of small details and most importantly some rear flood lights for when I reverse in the dark.
