- The Netherlands
- Flying
- Boating
Got any more pics of this car? That a-arm looks intetesting.For this price believe me, its ok. Glue should be done in 19 hours, if I take the instruction very literally. If this won't work I'll follow @WickedFog's advice and buy a front hub carrier of another car![]()
Oh, a drum brake. Pretty interesting.Notice the whay the braking system brakes? Never seen this myself on any other RC
On the hard body radio shacks, my little brothe uses a lighter and papermate pens casing and did his body work that way.I knew about this very effective thing in some cases.
How to make such effective liquid plastic at home
At this point, however, many are surely wondering "But, how to make effective liquid plastic at home?". First of all it is very important to clarify that we are talking about a plastic welding technique called chemical welding.
The first step to take should be to take a plastic object, such as the cover of an old record, and break it into small pieces using a suitable tool, such as small wire cutters. Once you have grouped all the small pieces of plastic, continue pouring them into a syringe and add pure acetone.
Leave it to act for about two hours and after this time what you will obtain will be a very strong and useful liquid plastic. This must be applied directly to the piece of plastic you want to repair, paying attention to the quantity applied.
Another way to repair broken plastic is to create a thicker compound using acetone and polystyrene. This inserted inside the acetone will tend to melt and form a ball that can subsequently be used to repair the plastic.
Specifically, in this case it is recommended to use metal adhesive tape to apply directly to the damaged plastic. And on top of this tape then apply the previously mentioned compound made with acetone and polystyrene.
At this point you simply need to leave it to dry for a maximum of 24 hours. And precisely after these hours it will be possible to eliminate the metal tape and notice how the repair in question, as well as the one mentioned previously, turned out to be efficient.
This guy does custom decals and has a lot of premade designs already. He can fix ya up.Hi all, I'm new here. I have a Carson Dazzler that I'm resorting, would anyone know where I can get the Decals from?
Nice to see someone else with a dazzler. I thought it was actually a very rare RCHi all, I'm new here. I have a Carson Dazzler that I'm resorting, would anyone know where I can get the Decals from?
