Nice Score Sweetdiesel!
By the way, for some that don't know the diff in an oiled compressor and a non-oiler :
If you look close at the pic, you'll see a pipe sticking out from the crankcase,,that is to drain the oil when changing it. And you'll see 2 humps on the motor, those are "starting/running" capacitors and are necessary to start an "oil type" compressor as it is more of a work horse, rather than a bumble bee gathering pollen (non-oiled type) and requires quite a bit of starting current which is inductive by nature and requires that the power factor be compensated by capacitive reactance, or "negative inductance".
An oil type has a very long stroke compared to a "non-oiler" and builds pressure ALOT faster than a non-oiler, and in most cases, is rebuildable as most non-oilers are not.
Jeep
