Bec issues
Epic guy
Hey guys, i recently bought a "no brainer bec" i plugged everything in and my car started smoking. My esc's bec wire was burned on the negative wire. Let me know what other info you need. Please help.
hello.bummer did you remove esc red wire b4 turning power on .if you did not thats what caused issue.. remove red wire center wire from esc to rx. it has a small tab on rx plug the contact will then slide out of housing . shrink-wrap that contact and a small amount of wire. try powering on again. not sure this will fix all esc might have been burnt due to the new bec install b4 removing red wire
Where do I remove the positive wire from? If it is from the esc then how does the reciever get power. Also what is rx
bummer . red wire on esc bec is plugged into receiver(aka. rx.. radio is tx) rx can go also.int installation instructions tell you this?
