• Welcome to RCTalk! šŸš€
Battery doesn't want to fully charge
DavidB1126
Team Bomb Pop
Bomb Pop Island
Maclan V3 6100 2s
What's the balance current rating for your charger?
It's clear your cells are degraded and no longer matched with the IR being 1.4mΩ apart, chances are it will eventually balance but is clearly taking longer than you prefer.
Some chargers will let you disable the balance mode and charge to standard 2S voltage at 8.40V and that will gitterdone knowing the cells aren't matched and they'll discharge unequally regardless. Just know that the battery is on it's final leg and the time has come to replace it.
Chances are a charger with a higher balance current rating will make the battery limp along a little farther but for stock racing I wouldn't race with any cells higher than 2mΩ if you want to get the best possible performance out of the pack.
Good Luck!
So those voltage numbers are after a balance charge timing out? What is your time out setting? Same thing happens on channel B? I don't think it does, but does the charger have calibrating setting?
If the constant voltage part of the charge is "taking forever" to complete, then most likely the cells are far apart in terms of health.
I'll try that after dinner
At the track last time. it did the same thing right after storage charging it.
The other battery in the pair is still good.
Did you try storage charging it?
