Backplate leaking fuel
Daniel J
RCTalk Qualifier
Liverpool England
  3. Flying
hello there. I got an ftx carnage out my money and when I try to start it my backplate leaks fuel. If I need to to seal it, how do I do it what things do you need? My engine just won't start as well. Thanks
Well, you can try sealing the backplate, but if it's leaking around the starter shaft badly, you will need a new backplate, starter shaft and I'd suggest a new one way bearing. Using an old bearing on a new shaft can cause excess wear on the new shaft.
