JimmyJamNitroFan
Ok so I started noticing after I had taken my backplate and pull cord assembly off and put it back on that the pull cord had a dead spot in it sometimes. Like it would just have no resistance at all for a few inches and then would catch and other times it wouldn’t be there. I Andes up taking the pull cord off and when I did the hex head on the back of the back plate that inserts into the hex part of the pull cord assembly just pulls right out now. Like I can pull it right out and put it back in. It still works to turn the engine over when the thing is seated correctly in the pull assembly but I think my dead spots are coming from it moving freely in and out of the back plate so sometimes it is catching and turning the engine over and others it is just not seated and not doing anything. So this thing should not be able to be pulled out like this correct? So why is it and what do I need to do to fix it?
Thanks in advance!!
Thanks in advance!!
