Axial scx10 Deadbolt body dimensions
Jimbobjr
SE PA
I could not find the length or width of this body anywhere. I’d like to incorporate it in a build. This info as well as the width at the fenders would be extremely helpful. Thanks!
Jim
My deadbolt is Length = 1.9cm Width = .82cm
Overall length I had to measure with my imperial dial calipers.
7.575" or so long, which is 192.4mm long
Rest are in metric. Divide by 25.4 if you wanna know imperial measurements.
Wheelbase can be found on the hobby shop sites. This is just a visual aid. Actual wheelbase - 5.25" (133.5mm). I was close lol.
View attachment 159903View attachment 159904
thanks so much guys but i was looking for the scx10 (1;10) version to use the body on a crawler i have.
DOH! I didn't catch that either. :doh:
Found a clear body on amazon and it says the dimensions are:
BrandAxial
Item Dimensions LxWxH18 x 8 x 5.38 inches
MaterialPlastic
Number of Pieces1
Included ComponentsDeadbolt Body Clear .040
BrandAxial
MaterialPlastic
Number of Pieces1
I think that includes the uncut bits. Pretty sure I've found the measurements , just didnt look hard enough the first time. they are 17.5" X 6.25".
Really liking the new redcat gen9 Scout two door but its too chubby for what i want to do. Hopimg the deadbolt width will be skinny enough for my punks customs capra build. Going to try and slam the body and chop the rollcage like this.
The Deadbolt does taper off at the back. The front has a lot more clearance in the wheel arches.
But the Capra "body" is the chassis. So how are you going to put a Lexan body on it?
I built a Punks Customs chassis kit. It uses the Capra axles, links, shocks, trans and drive shafts. It really does well and I like the creep body, just might try the deadbolt on it for a different look.
https://www.rctalk.com/forum/threads/punks-customs-3d-rc-stagedive-chassis-kit-build.137255/
