I was working on the diffs last night and noticed a good amount of side to side slop at the axle hubs.
The rear is much worse than the fronts.
I am assuming this is normal on the AX10 as with almost all rigs, but since I race on-road touring cars and such, I find it to be unacceptable and will shim them so there is very little slop. Slop like that in a touring car would wreak havoc on handling.
Hopefully I can get some shims tonight when I go racing to fit inside the bearing recess on the rear hubs. I found enough to do one rear hub.
I realize these things aren’t subject to the handling issues of a race rig, but to grab a hold of a tire and have it go clunk clunk clunk back and forth without doing something about it would drive me insane.
Most guys running crawlers dont care since at one point in their life they will probably end up gaining slop anyways with enough use. I used to shim the pinion gears on my tlt axles and they lasted me well over a year before I had to add another shim. While others were running them with some slop between the ring and pinion gears and they would constantly take teeth off the ring gears.
