Associated T6.2 project
ARRMAgeddon
RCTalk Champion
808 state
Another project on the bench while waiting for parts for other projects
So many project so little funds😆
This project pushed on the side for a while
Wanting to get back to nitro
At one point i wanted to trade this for a running rc10 gt
But no one seems to be interested
So continue with the project
Need a little help tho
What pinion gear would you use with this set up?
I want to go ballisitc with this build😁
What are you doing with the car? By the tires looks like a clay track setup? If your racing on clay, or any other track tbh, it depends on the size and layout.
For me for my B74.1D. On a medium sized indoor carpet track, I am running a 21T, 78 Spur, 13.5T motor.
I would say start with a 20T and go up or down if and when needed.
Max10. I use that same combo in my rustler, just with the 4000kv motor. Should be a decent combo for the track.
I dont race i just like rc to play on the street
Tires were just given by a friend
5400KV???!!!!
I would go through some setups here and my starting point would be 18T or possibly a 17T pinion:
https://site.petitrc.com/setup/associated/setupt6.1/
Mainthing i don over heat is good enough
I use the 4000kv HW motor, with this esc in my rusty no problem.
The lower kv, like 3300 might be the best.
Lower kv = more low end torque, less speed
Higher kv = more high end torque, more speed.
This can also be because of gearing too.
I would only use 5400kv for the track, depending what the class and rules are. But like I said before, it can be done, just watch motor temps, and experiment with gearing with the temps.
Thanx man
