Anyone used a drone battery in their crawler?
Relimar
RCTalk Champion
  2. Crawling
  3. Scale Builder
My eco power 3S, 50C, 4400 mAh batteries are getting worn, so looking around and that type of small form factor "trail" battery seems to stop at 2200 mAh. Found a CHNL 3S 90C, 6600 drone battery that's roughly the same size, albeit about 2x as heavy.
Thoughts? What are people running?
That pack should still work if it will fit. Both seem huge to me for a crawler though where weight distribution is a big factor.
Sorry mistyped, the eco power is 4200 mAh.
I land on the trail end of crawlers, where I want an hour plus of run time per battery. I have seen a bunch of comp guys with these tiny batteries, but they're 10 mins max on a course.
The eco power I have now is 44x105x24mm and 220grams
the CHNL "parallel series" drone battery is 45X55X101mm and 490g
with an scxpro chassis, I've fit a longer style battery in there before, wondering if I should go that route instead of screwing with these small odd spec batteries
I get an hour from 450 mAh 3s lipo battery weighing 46 grams, and 31 minutes from a 300 mAh battery weighing 30 grams. This is running heavy-duty direct power servos. Battery weight is a killer for performance. A handful of the 450's would keep you crawling for some time, unless you're mashing throttles while trailing.
Tons of options on Ebay to look through.
Well, as long as it's the same voltage, battery chemistry, etc it should be fine then.
