Anyone got a how to on putting a tmaxx back together?
You mean the exhaust oring? Yeah it will run but maybe a little lean and throw oil all over the back of the engine and ez or pull start.
Dont run it without oring on head. Not good. If it will even start. Changing the size of oring on cooling head changes compression. As far as ez start oring it doesn't have one. Just a owb on shaft. There is and oring in between the backplate and block but not between ez start and backplate.
I did get that oring gasket mailed yesterday for you. You should get it tomorrow or monday.
I'm headed to bed buddy i will check with you tomorrow and hopefully the mail ran quick and got that gasket to ya. I'm gonna be hungover for sure!!
lol alrighty Z get some sleep,
question, I've got the new steering servo connected and with the battery on it turns fully to the right but the left isnt even enough to turn.... any ideas?
What kind of TX are you using? You will have to take off the servo horn from the servo, turn your rig on then '0' out your steering trim then re-connect the horn with wheels straight.
the horn or 'arm' is what your steering assembly connects to.
^^No those arent my hands, damn sissy hands.
(Horn) its the part that goes to the servo that connects to the toe link that connects to the steering bell.
---------- Post added at 10:10 PM ---------- Previous post was at 10:09 PM ----------
Yes those are your hands,admit it....
ahha! the white piece !!!
thanks !
No worries, its like I'm sitting next to you 'not' drinking and just answering your Qs, its fun! :hehe: (not the sober part)
NO Nikko theyre not, mine have long painted nails with sparkly glitter on them, OH MAH GAWD SO HAWT! :hehe:
I never wash my hands unless dealing with food or my son, other than that I am feral :D
Yep, his hands! Those little fingers are what stopped him from saving his truck, he could grip it so it hit the water.
ya mine is a white circle piece........ just for a heads up do i "reset" the throttle the same way ?
Yep, just get the carb closed and no drag on the brake.
speaking of carb......does this little screw go into it somehow? I've got no idea where it came from lol, i didnt take the carb apart so I'm thinking maybe its part of it somehow
thanks for the help !!
On the side of your throttle it looks like its the LSN? If so screw it i just feather tight. But I cannot remember if they get o'rings.
Movie time with the wife, catch this in the morning. :D
Looks like it may be the idle adjustment screw, it also looks like you're pretty rich on the LSN. I'd also grab a new blue "boot" for the throttle, it keeps dirt and dust off of the slide.
