AGFrc Servos
RustyUs
Military Veteran
Build Thread Contributor RC Showcase: 9
Pennsylvania, USA
AGFrc servos... the thread for the good; the bad, and the ugly posts on the brand.
Just a few links from AGFrc:
Standard size servos... HERE
1/8th Scale servos... HERE
Low Profile servos... HERE
Spare gear sets... HERE
I can't attest to their standard size servos, but their 1/5 scale servos are phenomenal. I have the AGFRC A280BHMW 78kg in my Kraken Vekta that weighs nearly 50 pounds. I also have the oversized (220mm / 8 3/4) Maxxis Trepador tires on it and that servo pushes them around with ease. They are expensive, but worth it if you need a powerhouse.
78.0 kg-cm (1084 oz-in) @ 8.4V
0.082 sec/60° @ 8.4V
I'm using two of the AGFRC red 32kg coreless digital programmable servos in my Vanquish 1/10 builds and they are doing a great job. I've watched several servo tests on the 'Tube that show them greatly over-performing their torque specs.
I've only had them for a very short time and they haven't seen much use but, so far, I think they are a very good bang-for-the-buck servo. Time will tell...
I bought four (4) of these 55kg Servos for 1/8 Buggy steering, and three are still working. The fourth started having problems holding center, I did pull the top off and didn't see any stripped gears but obviously didn't dig deep enough. Also had a shipping issue with one of them - there was a much cheaper servo in the packaging (they did make that right). They are almost too tall for the Tekno RC's servo mounts, but they work (tight against the chassis). Cable length is just long enough to make to the Rx on the EBs. I do like them and am still running a few.
AGFRC 55KG Digital-Steering-Servo High-Torque Waterproof - Programmable Metal Gear Brushless RC Servo (A86BHMW)​
I have since switched to the Tekin T300 for future duty based on recommendation of a buddy. Those aren't as tall/fit better, but the cable is even shorter than the AGFRCs?...
I've quite a few of them now, my goto top spec servo.!!
The 1/5 scale ones are just nuts, got a couple the 78kg and 100kg, smaller standard size crawler ones and low profile ones too.. 😎
So far I can't fault them.. :thumbs-up:
I'll add the model numbers here later
That's good to know and unheard of these days.
@dustyroller
Yeah, I remember reading that somewhere. Even the Servo Programmer is using the same case. It's so lazy. Like spec a different case design. At least try and throw us off the scent.
I have a few Reefs but I'll most likely look elsewhere going forward for better value.
Reefs, Nsdrc, shift and a few others from what I’ve been told and read. Even some saying Injora on their higher end. Personally I’ve had great luck with them and have a go to replacement, even better when on sale I’ll grab a few.
To my knowledge Perfect Pass are also AGF, I always buy the genuine AGF’s all other company’s just tack on extra ££$$ just for fun, I’ll stick with the OG’s thanks and save some human monies 😎
Now that I've been using these two identical AGFRC servos for a while, I've noticed that one of them is quiet but the other emits that annoying high-pitched servo whine whenever it moves. They are both in Vanquish 1/10 kit builds (Optic and Origin Classic) using identical FlySky receivers and Hobby Wing motor/ESC combos. The noisy one is in the Origin Classic.
I've tried changing the servo voltage between 6V and 8.4V and that doesn't help. Any ideas?
These are the OEM for Reefs, correct?
@dustyroller
Yeah, whenever the OEM subject comes up, there are times where conversations got heated. I'm sure the rebranded servos have a component or components that are "better than" what comes standard in a run of the mill AGFrc servo to somewhat justify top tier servo price/warranty. There are posts/comments out there in the www with owners of companies that use AGFrc servos for their own brand of servo/product. The following is just one snip of a post...
You guys want to get deep into "re-branding", Search "TalkBass Mas Hino Warmoth"....
Seems like that chap got ripped off on that git-ter. Bummer. That seems almost like robbery instead of "healthy" profit margin.
Like a savox whine? Maybe installing a ferrite choke on the one classic?
I'm not familiar with "a savox whine." It emits a vey high-pitched electronic whine when in use. I'll try a ferrite choke. I have a bunch of them in my drawer of ham radio stuff.
But they both work as they should?
Doing a dry run/testing of servos when I get them, the last two A73BHLW V2 40kg servos that I got had different sounds to them when operated/putting some resistance to them. Not enough of a difference in sound volume/pitch to concern me.
I got no answer for you other than they were possibly different batches with different components used during assembly.
Interesting read... https://jbeech.com/edu/bestpractice/on-why-some-servos-squeal-like-a-stuck-pig/
