The metal base of the front of my Aeroscout has come loose for the second time, due to some rough landings. The front of the metal wheelbase seems to bear the brunt of the force when this happens.
See the attached photo. You can see a gap in the front of the base. That is the "steady state" position of the base now. That is, if you push the front of the base down, it just pops back up and resumes the gapped position. No other cracks or damage to the fuselage around the base, or anywhere else.
It flies and lands fine this way. But I don't want it get worse, and then require a major repair. I would like to seal things up and prevent further movement or gaps, as I chalk up more landings (some of them inevitably not perfect).
When this issue first occurred, I put a bead of E6000 around the base to seal it against the fuselage. But after a few rough landings, the bead broke and the base came loose again. Same for 5-minute epoxy that I tried next. The sides and back of the base held, but the front bead separated from the fuselage.
Keep in mind that the picture you are seeing is after I removed the dried glue, in preparation for my new approach to the problem, which I will describe below.
I want to keep this repair simple. I'm not willing to take the landing gear out, insert screws, do a lot of fabrication, etc. like I have seen on other videos. I just want to plug the gap, tighten the base against the fuselage, and prevent further loosening, as much as possible.
So here is what I am thinking, and I would like your comments and remarks. Bear in mind that there are always more than one way to approach these repairs, but I like to keep things simple and functional:
1) I plan to shoot some E6000 (or maybe something else, like Foamtac, which has some give to it) into the front gap, enough so that it will fill the gap. That will hopefully prevent any more up-and-down movement of the base. Basically, the dried glue will shim the front of the base into its current "steady state" position.
2) Then I will simply put a bead of some glue around the entire base, which will hopefully glue the base to the fuselage. Not sure what I will use: E6000, 5-minute epoxy, maybe Foamtac? (But I believe the latter is only for foam-to-foam repairs, not metal-to-foam.) Open to your suggestions.
3) Then I will cover the bead after it dries with some Gorilla Tape, just to seal the seam from the elements in case I bang into anything like grass, etc. with the front wheel. So it will protect the seam a bit.
What do you think? Does this make sense? Anything I am obviously missing?
Thanks
Thanks
