Berto
Hi and sorry for the long post.
I've been researching Lipos and I’m starting to get a handle on them but wanted to check my info before I jump in.
So if I have an example S2 3300mAh 30C.
That means it has 2 cells in series (S).
Capacity (C)= 3.3Amps or 3300mAh.
Voltage (V) = 7.4Volts.
Max load (30x3.3) 99 amps.
Storage should be at around 50% capacity which is 1.65amps.
You shouldn’t drop below 80% capacity, 0.66amps, before stopping use.
Charge rate should be 3.3amps and discharge would be 1.65amps.
The Max current of the battery should exceed the draw of the ESC you are using.
More capacity means more run time but also can mean bigger batteries.
I need a Lipo bag or ammo box to store and charge them in.
Is that correct and have I missed anything?
Can anyone recommend a suitable charger?
For an ESC of 60A (continuous running a 4250kV motor, is 3300map 2s 30C suitable?
And finally I’m from
The Uk and was wondering where does everyone buy online? I’ve found a few (modelsport, wheelspin) but would love people’s recommendations of places to buy more batteries and accessories.
Thanks to TNTproof for giving me a point in the right direction.
