street silence
RCTalk Champion
Is this what you are looking for? https://www.amazon.com/Gear-Head-RC-Battery-Holder/dp/B013RVOZ0E They also make a 2AA version: https://www.amazon.com/Gear-Head-RC-Battery-Holder/dp/B074JJX7K6I wanna install this led strips but have no open source on my receiver. Do they have a switch or cable out there?
Is there a cable to connect it to the batt. side on the receiver?Is this what you are looking for? https://www.amazon.com/Gear-Head-RC-Battery-Holder/dp/B013RVOZ0E They also make a 2AA version: https://www.amazon.com/Gear-Head-RC-Battery-Holder/dp/B074JJX7K6
Those are completely separate units that have their own switch, and you just put in AA or AAA batteries. They are completely self contained, so that they dont need to be connected to the ESC or the car battery. The power comes from the AA or AAA batteries..Is there a cable to connect it to the batt. side on the receiver?
Sorry but I have no idea what you're talking about.So I had gotten one of those charging switches & have to remove the battery & plug in both the switch with the charging port and the battery for it to charge with a y connector
This is what I mean. One is for the wall charger & the other comes from the battery. As soon as I connected my AE rx charger it broke the plastic that holds the cable it just snapped outSorry but I have no idea what you're talking about.
This one broke as well I just switched the cablesCan you post a pic of the broken piece?
IDK what you're trying to do. you're holding two male ends as if they go together, or at least thats what it looks likeThis is what I mean. One is for the wall charger & the other comes from the battery. As soon as I connected my AE rx charger it broke the plastic that holds the cable it just snapped out
You needIDK what you're trying to do. you're holding two male ends as if they go together, or at least thats what it looks like
I've run into almost this same problem. I bought this battery case (they also make them for 9V) but the various lights I have also have a male plug. I tried searching for a female-to-female adapter with no luck (although there are plenty of male-to-male adapters available). Is it impossible to have a female-to-female adapter for this type of connection? Does this type of connection have a name?
One of them is from the battery (the second picture) to the receiver. The first picture shows the charging switch cable, it has a charger plug so you don’t have to need to remove the battery. That’s the red cable it goes directly to the wall chargerIDK what you're trying to do. you're holding two male ends as if they go together, or at least thats what it looks like
The plug coming off the battery pack needs to plug in to the "batt" slot of your receiver which in the first picture it looked like it was even though its connected via JR connectors and typically that should be a futaba connector. Where ever you're trying to plug those various futaba connectors in that you are saying keeps breaking is still a mystery to me. Keep trying to explain and supply pics (or a video would be even better) of what you're trying to do. Hopefully we'll get it figured out eventually.One of them is from the battery (the second picture) to the receiver. The first picture shows the charging switch cable, it has a charger plug so you don’t have to need to remove the battery. That’s the red cable it goes directly to the wall charger
