2.4 ghz radio issues
ch3no2junkie
Valdosta, GA
I was out working on the tune on my barely 2 month Revo 3.3, when I started having radio problems today. It would loose signal for a second or two, go to idle, and theng back to normal operation. I was able to the red light on the rx come on when it was doing it, and go green when normal operation came back. I changed the batteries in the tx, but that didn't cure anything. The rx battery had only been ran for 10 minutes since the last charge. It's the stock Traxxas pack, but I charge it with a dynamite prophetsport charger set on two amps. I Know it's not a range issue, because the truck never got more than 150 feet away from me. It probably glitched once every 10 minutes over the course of an hour of running. Anyone have any suggestions?
I'm having similar problems
BRAND NEW JUST BOUGHT IT FRIDAY....
I can't get the car to keep the bind..... I've tried to re-bind but its not working..... the car and radio are both off, i put the bind plug in the bind spot and turn the power on to the car and radio. It will sometimes bind then when i turn it off and remove the bind plug and turn them back on only the servo for the throttle will come on and not the servo for turning.... i've done this probley 30 times today and it just keeps loosing the bind when i turn the power off..... the only way i can get it to work is leaving the bind plug in and re binding everytime..... :\
