Dude, lfirst off, the T Maxx clutch bells have a different pitch to the gears, so I would have to change over to a Traxxas spur gear. (which is possible) But I would also have to cut the crank off of all my engines, and buy all new flywheels, clutch shoes, clutch bells, bearings, and on and on and on.... Plus, I'm not 100% certain that the CB would line up with the spur gear unless the engine mount is relocated farther toward the passenger side of the truck. Not to mention, the end result would be using a 10th scale clutch, designed for a 9 lb small block powered 10th scale truck, on an 1/8th scale, 12 lb truck, with a 3 HP modified Picco .26 in it.
I have had big block T Maxx trucks before, geared 22/64, with an Ofna Hyper 21, and yea.... it ran good, but it had no where near the power of a stock Picco .26, much less a modified Picco .26.
Back when I had my big block truciks geared that steep, the stock clutch shoes only lasted about 1 or 2 weekends.
So, no, I'm not going to go cut the ends off all my cranks, buy all new clutch parts for a T MAXX that I already know won't hold up in my MGT.
Like I said, I already found a 20 1/8 scale cb. THANKS ANYWAY.
