Here's a build showcase of my Traxxas XO-1, I originally bought her as a V1 roller on July 4th 2022 off eBay from Cash4RC for $400 without body, wheels, tires or electronics. Over the years i've built her up to where she is today.
This picture is what she looks like today.
Here's some pictures without her body.
My most recent run with this car with the new radio. As of 3\11\2026
As you can tell she's mostly stock except for velcro battery strap mod just 20 x 500mm Apex RC straps wrapped under the stock battery holders since i run my two Zeee 3s 6,200Mah hard case batteries in this car. I also have a GPM Aluminum bellcrank in Blue as well as sway bars
Her current setup.
Castle Creations Mamba Monster X 8s Sensored (Currently running Sensorless) Brushless ESC
Traxxas\Castle 1717 Big Block 1,650kv Sensorless Brushless Motor
Perfect Pass QS8-V2 600A Max 8mm connectors soldered onto both ESC and Battery leads
Traxxas 46 Tooth mod 1 Steel Spur meshed to a Traxxas 16 Tooth Mod 1 Steel 5mm bore pinion gear (Have plans to gear up someday)
Amazon Special DS3225MG 25kg Servo running at 7.5V although it's max rated voltage is 6.8V
Spektrum iXSR+ 12 Channel DSMR\DSMR+\SLT 2.4Ghz Android\Raceware touchscreen computer Transmitter
Spektrum SR6200A 6 Channel DSMR AVC 2.4Ghz Receiver
x2 ZEEE 6,200Mah 120C 11.1V 3S LIPO Batteries with Perfect Pass QS8-V2 Connector soldered on
Traxxas GTR Hard anodized threaded aluminum body shocks filled with unknown fluid
Traxxas Revo stock differentials filled with 500k fluid front and rear
Traxxas stock split spoke black chrome 3.3in wheels with stock Traxxas S1 belted slick tires
Traxxas 2022 XO-1 stock custom painted body in Red with Arrma 1\8 body clips with lanyards.
Has Apex RC battery straps put under stock battery holders
Traxxas REVO\Slayer\Summit Blue rear and Silver front shock springs
Here's some pics of her back when i got her and got her up and running for the first time.
Current top speed (Running on 6s with 16p\46s).
Here she was when she got hot off the UPS people was originally going to use the Hoons but decided to use stock tire instead. This was back in July 2022.
Here she is with her original body and tires. (Which i still have)
Here she was after my first run with original setup and stock gearing on my old Zeee 3s 7,000Mah 100C batteries
Future Plans.
Upgrade the Servo to a higher quality and stronger unit
Get a new pair of 3s batteries like gensacearespammers or CNHL
Buy and paint up a new V2 stock body
Get a new pair of tires either stockers or Pro-Line Toyo Proxes R888R S3's front and rear
Her current setup.
Future Plans.
- RC Type
- Car
- RC Brand
- Traxxas
- RC Model
- XO-1
- RC Scale
- 1/7 Scale
- Power Source
- Electric
- Battery Type
- LiPo
- Motor Type
- Brushless
- Drive System
- 4WD (Four-Wheel Drive)
- Top Speed
- 40-59 mph
- Budget
- Over $1000
- Challenges Faced
- Debating on power system (Solved), Debating on selling it to buy a new 2022 XO-1 (Solved), Finding the proper place to run over 100mph, Trying to get it handle good while street bashing (Solved).
